Currently reading:
Continuity check??
Discuss Continuity check?? in the Australia area at ElectriciansForums.net
:confused:Hi guys,
Could anyone educate me as I'm no way near as good as ok..!
Had a problem which I've previously posted on your forum, about GU10 downlights, my question is..
If you were to be doing a connection check on the terminal strip of the downlight( earth to common earth to live )?
What reading would you get (open or closed)???:eek:
Man you've lost me already here. Been reading about continuity ok but I could not make out how the fuse in consumer unit kept flippng. I had bought 6 downlights GU10s ÂŁ20 including bulbs and fittings off the internet and wired them into the switch live on the old ceiling tube light we have in the kitchen How I wired them were all in tandem, with two wires in, including the earth then on to the next and round to the existing old ceiling rose, then "clip" it went dark again and again..!!(Also the only colours were the Y/G earth)
Anyways the gooder news were I went to toolstation and bought low voltage downlights which seems to be brighter and the flippn problems don't seem to exist,with (br)live and (bl)neutral
Please any answers mate..
Cheers
stop reading and pay a sparky
from what you are saying is that you carried out notifiable work in a kitchen with out been registered or having any intention to notify the LABC, oh and ÂŁ20 + bulbs probably means they were crap and not fire rated!
eh!! eh!!
nail on head , say no more!
(DB) is something board, as I,ve said here before you guys are the NUTS here(brilliant) and I,m a plumbing student so please bear with us please.
Our place has recently been refurbed (about 3-4 yrs ago sos its pretty up 2 date) and we have (BR)(BL)(YG) just love to get behind the knowledge of blue wire when and what it means when its sleeved with an outer casing What does that mean
Must say I'm quite enjoying it here at the electrical forum
, a bit worrid about my outgoing expences, on another fotune on doing an electrical course LOL..
Cheers
when one cable is sleeved it usually means that it is a switched live, or that it is a permanent live and the electrician before ran out of the correct coloured cable.
but as others have said, get someone who knows what they are doing in to do it. It might cost you an hours labour, but you won't get killed and nor will anyone else.
Thats mad man, the plumbing parp (P) actually illustrates the elctrical circuitry of lighting and switching here c'mone!!!
Say if you were that much of an electrician yourself you'd know the ins and outs of wiring progrmmers to boilers etc??
don't do boilers!! leave them to heating engineers who connect the gas up at same time..! too many cooks and broth come to mind! should be that way with plumbers and consumer units and lights!
but S and Y plan are you on about though!
not going to even attempt to get angry at you! with your wiring you wont need heating! :) good night!
Thanks Steve, but say if you were to get a battery and put the +- together "spark"..
I got testing ok the earth negative and positive when crossed with probe all give a reading,(I mean the needle goes from left to fight all the way to zero on meter)
Is this open or closed reading ..
Actually I'm thinking of putting a logo at the bottom of my profile page that say!! I've got a lot to learn,IF IT AINT BROKE DON'T TRY AND FIX IT!!
Spanner, I agree you should be very careful at your stage of learning (that goes for all of us), but, to go back to your original question of continuity - as a plumber you'll be familar with water flows, so to the principle of continuity can be seen if you think of electricity as water - would it work if it was a piped system? The safety issues are more complex, but if you think of flows, capacities and pressures then analogies with electricity will make sense. Best of luck; but never take chances - water makes you wet, but electricity kills you.
depends on what type of test meter you are using!! when i get an open circit i get >299
closed circuit i get Beeb and a reading of 0.00+ (depending how much cable im testing)
but i know some test Meters (B&Q style) show O/C or OL or words to that effect...!
Yes, Durham is right - just check the meter instructions; they'll give you the limits for the meter readings, but no problem - your previous assumption is spot on. Closed may give you a 1 as out of range or <something (ie greater than the normal meter readings), but open will always give a result close to zero (no or little resistance to water or electricity flow when tap or switch is open).
Reply to Continuity check?? in the Australia area at ElectriciansForums.net
