Hi everyone. I have a doubt. If I have to test a ground pin of a 5V connector (suspect bad ground), to do a continuity test is it necessary to touch with the multimeter probe any point of exposed metal of the chassis? Or do I have to touch exactly and directly the negative pole of the battery?
Is it the same thing?
Thank you for help
Thank you for help
