You can get a switch PIR for your situation it does not require a neutral so easy to replace ordinary switch. The problem with them on a two way circuit is that they want to be wired a different way to two way switching.They have to be daisy chained type of wiring.
I didn't know about no-neutral pir, so I had a look in TLC and link is below. The unit draws power by passing a small current through the load when in the off state. When it turns the load on, there is a little rechargeable battery that takes over. Interesting ...
https://www.tlc-direct.co.uk/Technical/DataSheets/BEG/BE180R2W_User Instructions.pdf
Danlers make them as well.
WAPIR - DANLERS Lighting Controls & HVAC Controls - http://www.danlers.co.uk/pir-occupancy-switches/45-products/pir/pir-occupancy-switches/wall-mounted/36-wapir-wall-mounted-pir-occupancy-switch
