Discuss convert 12v gu5.1 to mains gu10. in the DIY Electrical Advice area at ElectriciansForums.net
nittinsh
convert 12v gu5.1 to mains gu10. but confused why this transformer has two live wires? can someone explain.Do I need a driver or I can directly attach GU10 holder to the mains? and what should be done with second live wires?
Does it feed out to a second unit?
Downlights rarely come as a single unit, so I expect you have multiple downlights, so one of the cables will be power into the transformer, and the other cable will be power onto the next light.
Most GU10 fittings are designed to take two cables, so you should be able to connect both directly, but try to make a better job than whoever fitted the original. ALL single insulated wires (the red and the black) must be completely inside the terminal box, and the cable clamps must be on the grey sheath.
Alternatively, if the new fitting's terminal box is on the small side, as many are, you can use one of the small MF lighting junction boxes that are now available to join the two cables, and add a short flexible cable to the fitting.
thanks seems like a lot of work
Not really, this is straight forward if you know what you are doing.
My advice if you are unsure get an electrician in to do this. They can advise if there is anything unsuitable and if its just a straightforward swap out then it won't cost a lot for the peace of mind that its done safely.
I managed to change that myself thanks guys for your help.
Reply to convert 12v gu5.1 to mains gu10. in the DIY Electrical Advice area at ElectriciansForums.net
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
I am sending power to some 5v led lights about 50ft from the transformer. I was going to use some CAT6 direct Burial cable that I kept after a...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
