Discuss Converting to a TT system... possibly in the UK Electrical Forum area at ElectriciansForums.net
1.25ohm external earth fault loop impedance on TN-S supply to building
Supply authority stated our only option is a TT conversion as they will not covert to PME.
What would be my best course of action when converting to a TT as the building is quite old and i do not want a 100ma main switch for diversity reasons and nuisance tripping, so Would it be suitable to convert to TT and have all final circuits in a RCBO with a board charge?
Page 33 OSG (yellow) has an example you're suggesting, i.e. for new A3 CU's.
Wylex have just released a SPswN RCBO, and use a bespoke gland for tail entry.
Thank you Midwest looking at page 33 is quite useful
on a side note i want to avoid hammering a TT rod through a gas pipe, i have never installed an Earth mat are these a viable option as the property is surrounded by soil/grass
Never installed or seen an earth mat, guess someone here has, or perhaps ask one of the manufacturers.
Out of curiosity, why won't your DNO convert to PME?
A sweep with a cat, not the feline kind, should help you avoid any other services.
SDS adapter and you can have a rod in the ground in a few seconds with little effort.
One question, will the rod be a better bet than the poor TNS earth?
We install mats regularly.
You will still need to dig down about 300mm but you will be able to CAT scan the area accurately.
The reason mats are deemed safer is that most Permit to Digs instruct you to CAT scan every 300mm. You cannot do this when driving an earth rod in.
What is this SDS adapter as i normally use a club hammer?
Reply to Converting to a TT system... possibly in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
Afternoon all, Got a bit of a strange one (by my usual standards anyway). Job is a large barn conversion, done years ago, there's loads of work to...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
