I think it was an argument - sorry ... meaningful discussion - about the size of the green/yellow to an earth rod. I believe it's still here somewhere for reading.
To which my meaningful response would be whatever the adiabatic says it should be!
It's locked but still there Chris just look for the thread started by Axel Apparently he's neither an electrical engineer, spark or even employed atm.
hello all
just a post to check for advise please
taking my old cooker out the cable is 8mm
my new cooker has a rating of 9.1kw is this cable OK ?
specs, for my new cooker says ( cable h05w-fg 5x1.5mm 3x4mm )
why don't they just say 8mm or 10mm cable !
thank you Paul
thank you all
9mm never heard of that size !!!
cooker is 2m away from cunsumer box and is a free standing cooker with hob
local diy store have 6mm 8mm or 10mm
thanks paul
thank you all
thanks paul[/QUOTE]
Nuts and bolts, is that ?
hello all
thank you Paul
thank you all
thanks paul
Is that the CSA of the cores in the cable or the O/D of the cable itself ??
