Discuss cooker rating in the UK Electrical Forum area at ElectriciansForums.net
i have just bought a range cooker that is dual fuel, its mostly gas but has an electric hob/warmer, in the specs it says the max load is 7.2kw but it has a plug top? i need to put a socket in for it but not sure if i can use the existing wiring and downrate the mcb?
Rob
Something does not ring true.
You cannot run 7300 watts on a 13a plug top.
This will need direct connection on a separate circuit.
Normally run in 6mm cable.
are you sure the plug top is not for the spark to light the gas?
there is only a plug top, no plate for a fixed connection, the electrical side of it is only ignition and a small hob/plate heater so i would assume it doesnt pull much ampage, just referring to the literature that came with it says max load @ 230v 7.2 kw, which has me a bit confused
Is it possible that the user manual covers more than one model of your range and that they do a fully electrical version of it, and you have missed that bit in the instructions lol.
agree witrh sedgy. the kWratring for the cooker will include the gas equivalent on kw like they do with your gas bill, convert cu m to kwatts so you can't understand it.
if the appliance already comes fitted with a BS plug top from the manufacterer - then the power requirements have already been assessed for you.
Reply to cooker rating in the UK Electrical Forum area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
I have bought a cooker with a ceramic hob which has a warning light to show that the top is hot, the light goes out when the hob cools down. I...
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
