E
Elmocash
Hi, On a kitchen refit i found the cooker supply wired in aluminium pvc/pvc. I did a temp connection to give the client a working oven for the weekend. The Al cable is solid core of around 4mm, i connected new 6mm T+E in standard strip connectors with brass tunnel and steel screws. Thats a lot of mixed metals, any ideas of a permanent joint of Al/Cu. Cheers, Elmo
