R
Rhododendron
Hello folks, wishing you all a very happy weekend.
I'm just about to buy some cable to wire a 36w T8 Fluorescent light Batten to a 3 pin plug. (I will use 3 amp fuses & 0.75mm 3-core flex).
As these lights can get quite hot: would it be an idea to buy a Heat-resistant Flex cable? Or would standard PVC Flex be OK for this?
Any advice would be much appreciated.
All the best.
Thanks for your reply. As the light is used for curing polymers, LED's are not as good as Fluorescent UV in this case.
For normal lighting, I would of course use an LED!
