R
Rhododendron
Hello folks, wishing you all a very happy weekend.
I'm just about to buy some cable to wire a 36w T8 Fluorescent light Batten to a 3 pin plug. (I will use 3 amp fuses & 0.75mm 3-core flex).
As these lights can get quite hot: would it be an idea to buy a Heat-resistant Flex cable? Or would standard PVC Flex be OK for this?
Any advice would be much appreciated.
All the best.
A cooler running LED baton would make more sense!
But you can get heat resistant cable if concerned, such as this:
Thanks for your reply. As the light is used for curing polymers, LED's are not as good as Fluorescent UV in this case.
For normal lighting, I would of course use an LED!
  • Informative
Reactions: pc1966
If you can keep the supply cable well clear of the ballast, then non HR flex will do. I
Correct cable for 36w Fluorescent light batten?
Rhododendron,
brianmoooore,
