JohnNN
Hello,
I have a regular boiler doing room heating only, with a Drayton programmer (for time) + a Drayton dial stat (for temp).
I've bought a Honeywell T3 programmable stat to set diff temps at diff times.
Old Drayton stat (mains powered) had 3 wires (red, blue, yellow) + E (see pic)
New Honeywell stat (battery powered) seems to require 2 wires (marked A and B) and no E (see pic)
My thinking is that Red and Yellow are line in and line out, and that Blue was either used for powering the stat or for an "accelerator resistor". Image inside new stat (but not in instructions, see pic) seems to suggest something connected to N, so maybe that is still required?
Do I connect Red to A, Yellow to B and separately put terminal blocks on Blue and E?
Thanks for help, John
