Discuss Crimping Tool in the Electrical Tools and Products area at ElectriciansForums.net
S
SKY
Hi All
What do we think of this CK crimping tool? CK Crimping Plier 0.5-6mm | NoLinkingToThis
Need to purchase a good quality one for good joints.
Hi All
Is this one not the same just cheaper?
Ratchet Crimping Tool 1.5-10mm² | NoLinkingToThis
Looks identicle to me?!
TBH I have them Sky and also the black SWA branded ones. The SWA ones dont print a number but do crimp better - they seem matched for the crimps. Can I point out that the pre-insulated butt crimps from screwfix are terrible. I had trouble with them holding - adjusted the crimpers - no luck, called CK and they said they had loads of complaiints about the screwfix ones. I only get the SWA ones now for both crimpers.
Hope this helps.
Regards, David
Tool Trays-TTCP04 - Teng Tools 4 piece Ratchetting Crimping Tool set
I've used this on and of for a few years .
I like the interchangeable heads
Here's the specs:
TTCP044 piece Ratchetting Crimping Tool set
(265x142x50mm, 0.80 kilos)
Changeable ratchet crimping toolfor insulated terminals 22-10 AWG
(0.324 square mm - 5.261 square mm)
Die for non-insulated open
barrel connector, commercial type
for non-insulated open barrel connector,
commercial type 22-12 AWG
(0.324 square mm - 3.31 square mm)
Die for non-insulated terminalsfor non-insulated terminals 22-8 AWG
(0.3 square mm - 8 square mm)
The box is a bit light duty & the internal tray is crap , I filled the back of the tray with silicone to add some durability to it
I have no affiliation with the seller btw probably available for cheaper elsewhere
I use a Facom branded crimping tool which has stainless steel dies. Not cheap at around £60 but it's excellent quality.
ShowImage.ashx
forge steel from screwfix
Forge Steel Heavy Duty Crimping Tool | NoLinkingToThis
does the job nice.
bit cheaper than ck. longer handles make crimping easier.
Is it ok to crimp onto solid wires? I was always under the impression (from years ago working in the defence industry, admittedly more of a precision work on electronic connectors) that crimps should only be onto stranded wires - any comments?
If you worked in the Defence Industry I hope you've got a tin hat ....... I think you may need it very shortly. :tank:
I agree, and have also spent some time in defence equipment design. However there are many here who have no problem with crimps on single strand solid cable. It's probably OK provided that the crimps and tool are top quality and properly matched, which can be difficult or expensive to guarantee.
I bought the crimper in the OP in the end with the Electrfix discount it was £31.07 it works well but requires strong hands!
the s
Screwfix crimps however are rubbish as per the reviews on their website.
Having worked in the defence industry myself (ship refits in rosyth) we were in the habit of using calibrated crimping tools (my first job as an apprentice was calibrating said tools). Having left the defence sector quite a few years ago i haven't seen a calibrated tool since....lol That said good quality tool and crimps should be ok on solid cables
Reply to Crimping Tool in the Electrical Tools and Products area at ElectriciansForums.net
Good evening all. I have a couple of learners with hypermobility issues - which causes their hands to be sore after a day in the workshop. Has...
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
Hello everyone. What tool would I need if I were to work on a construction site doing containments? Thank you
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
