Discuss crimps? what should i buy-from where in the Electrical Tools and Products area at ElectriciansForums.net
mine are bog standard ratchet or is that rat**** from SWA available from any wholesalers. Less than £20 and have always crimped spot on
most crimping tools are good but id say (like jeremy) ratchet crimps are probably the easiest to use and there are an abundance of different makes from many different wholesalers
I have the same ones. Mine were about £13 and I wish I'd spent more - the jaws aren't symmetrical so if you don't position them spot on, the crimp will come off the wire.
Sometimes when using yellow crimps I find I have to turn the tool around and crimp it again in a different place.
There are some good pneumatic crimps availiable that have a swively head that do up to 500mm or there is a battery operated one by klauke out of a makita style 18v battery here Klauke Textron: EK60UNV. they really are the dogs for getting in anywhere.Also they do a cutting head for a really easy life.Also good for getting the offcuts chopped and into the back of the van unnoticed:)
Reply to crimps? what should i buy-from where in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
I'd like to refurbish the alternator for a 2005 CR-V. My plan is to replace the front bearing (the one closest to the alternator pulley) since...
i am looking to do some ESD testing on some electronics at home, where can i pick up a ESD simulator gun without a company
Hi, I currently have a Megger 1730 v1 which is fine for all functions except the 2 wire (L-E) no trip loop test, (no 3 wire loop test on my 1730)...
Hi, I'm new to this forum and trade as DF Electrics - Small Job Specialist based in Ellastone, near Ashbourne, Derbyshire. I'm now back on the...
