Discuss cross bonding bathrooms in the UK Electrical Forum area at ElectriciansForums.net
N
NealeElectrics
Hi guys this is my first post so bear with me, but what are your thoughts on cross bonding in bathrooms? Do you still need it if the installation is rcd protected with adequate main equip potential bonding is present?
not if disconnection times are within limits.
Reply to cross bonding bathrooms in the UK Electrical Forum area at ElectriciansForums.net
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Do you need cross bonding. Main gas and water incoming is plastic and all circuits are on RCBOs
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi I have a 1st fix domestic install on the go and need to leave a socket for other trades to use after me. There is no main bonding at the...
