Discuss CT metering help needed in the UK Electrical Forum area at ElectriciansForums.net
Hi guys,
I am going to a job Sunday and trying to gather as much info as possible before attending.
I believe I am looking at an elster a1140 export meter with an issue.
Solar PV on a gym, generation meter all reading fine (metered board for the inverters)...
The issue is with the export meter at the plant room, I believe this has its own 6A local supply but has CT connections around the incoming 3 phases. This has been in situe over 5 years now and has yet to register a KWH which is beyond belief.
My question is that how do I test the correct polarity on a CT, with it being export should the arrow point towards the supply or the load. If I have to disconnect the CT's do I have to short them out together before reconnecting?
I have never worked with CT's, I have searched youtube but I am just hoping for some basics on what my issue could be (hoping its a simple one!)
Reply to CT metering help needed in the UK Electrical Forum area at ElectriciansForums.net
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
