Discuss cut out fuses in the UK Electrical Forum area at ElectriciansForums.net
M
m1ck_b87
Hi all
Which fuse am I most likely to come across on a domestic property cut out fuse 1361 or 88
I understand that an 88 comes with bolt holes or clips and 1361 is a bigger version of a 1362 fuse
Concur with GS... Loads of 1361's about. I dont often see 88's...not sure what you mean re bolts... 1361's are indeed like super-sized 1362's....OR at least that is what I have been told as I would never, I repeat NEVER, pull a main fuse...... Much more preferable waiting for DNO to turn up and pull it, that way you can waste a couple of hours waiting for them....which I really appreciate as I am self employed and love to idly sit around because other peeps do not possess either a watch nor an A-Z....
Put UNKNOWN in supply characteristics box if not written on fuse carrier.
Reply to cut out fuses in the UK Electrical Forum area at ElectriciansForums.net
Hi all, any recommendations for neat and complaint ways to "house" a new supply -- the main electrical fuse, cut out, meter etc that on our house...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Had UKPN come out to a property recently to upgrade the main fuse from 60A to 100A but when they arrived they said that the supply cable which he...
