Discuss Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
pc1966
I find myself in the position of having to fit a few back boxes in to plasterboard. In the past for the odd one I just used a hand plasterboard saw to cut out a hole, but I wondered if anyone here has used something like the square/rectangular cutter adaptors you get for multi-tools to do this sort of thing. If so, how well did it work?
Suggestions for make/model?
TL;DR tips for cutting boxes in plasterboard
Reply to Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
Hey everyone, I'm trying to understand how to fit a metallic back box on a stud wall. Should it be fixed to a stud (on one of the sides) or is it...
5K
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi, I wanted to slightly re-route a badly routed 6mm2 twin and earth flat cable, that leaves my utility room through the plasterboard, the wall...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Recently sorting out first fix for a loft extension for a friend and ran into a situation I don't often run into (I avoid new builds usually) In...
7K
