As a few others have said... I use a multi tool rather than a jab saw. The plasterer politely (ish) suggested it as he said it was more likely to cut a smoothy, cleaner hole and he wouldn't need to return. He was right.
Fair point @nicebutdim However, the rapidity of the oscillation of a multitool or router creates much very fine dust which is rapidly airborne. A jabsaw is much slower and the dust is less fine, more "crumbly" and falls to the floor rather than becoming airborne.
That's my experience anyway...maybe I'm not skilled enough?
I always like the less intrusive approach for most tasks...yes, I still use buckle clips sometimes!
I always drill and screw rather than hammer, and I use a hole punch rather than a hole-saw to make holes in CUs and other accesories...gently does it!
So never used a Stanley Yankee driver in years gone by?I like the slower, gentler approach, which is probably just because I am an old git!
Change the blunt blade to a sharp one and cut right through that offending stud….The worst thing to discover having already cut into the plaster board is that there is a stud going horizontal/vertical in the way. It can help to use a detector around the area you intend to cut to eliminate this as once cut....
I use a laser to line up the boxes and mark before cutting
plasterboard…. Multi tool…. Go for it!This forum is very bombastic.Change the blunt blade to a sharp one and cut right through that offending stud….
I can’t believe this thread is at 25 messages already….plasterboard…. Multi tool…. Go for it!
Multi tool wide blade, decent green laser, and a template tool.Borrowed one of these once - 'Drywall cutout tool', found it really easy and 'quick' once got hang of it. More time consuming marking out the boxes.
A colleague uses one of those. It's good and the level is suprisingly accurate. Not sure that it's any faster than drawing round a box with boat level on top. If setting multiple boxes a laser needs to be set up anyway.
