Discuss Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
Thanks folks! Seems the multi-tool and wide blade is the best option. For me speed is not really important, more about getting the holes the right size and straight each time.
Multitool with a plastic cut out frame a mate made. The size is prefect for both single /doubles .Blade fits against inner side .I just offer it up and put the blade through.
The worst thing to discover having already cut into the plaster board is that there is a stud going horizontal/vertical in the way. It can help to use a detector around the area you intend to cut to eliminate this as once cut....
I use a laser to line up the boxes and mark before cutting
Change the blunt blade to a sharp one and cut right through that offending stud…. 🤨
I can’t believe this thread is at 25 messages already…. 😳 plasterboard…. Multi tool…. Go for it!
Borrowed one of these once - 'Drywall cutout tool', found it really easy and 'quick' once got hang of it. More time consuming marking out the boxes.
Reply to Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
Hey everyone, I'm trying to understand how to fit a metallic back box on a stud wall. Should it be fixed to a stud (on one of the sides) or is it...
5K
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi, I wanted to slightly re-route a badly routed 6mm2 twin and earth flat cable, that leaves my utility room through the plasterboard, the wall...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Recently sorting out first fix for a loft extension for a friend and ran into a situation I don't often run into (I avoid new builds usually) In...
7K
