Discuss data cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
Sparky_Ben
Just after a general idea on what tools are needed to work on data and bt phone cables for sky etc. Just want to try it in my home e.g shortening cables for neatness behind the tv mainly. any tips guys?
thanks
if you have an android phone, electrodroid app, shows pin out diagrams for RJ45 (ethernet) connectors amongst a wealth of other useful electrical calculators and references
Reply to data cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi, I need to run a duct from our garage, under the (gravel) drive to the house. Specifically this is for a monitoring sensor needed for our...
