J
Just had my result back - Distinction! - now just to wait till end of May for my time booked off - to start the project.
Started the project the other day, and got a few questions about random stuff that people might be able to help me on. Can we fix onto steel cladding (ceiling) ? some of my lights are high bay fittings (fittings I have found weigh 4kg)...and majority of the fittings do not line up with girders (as I was going to use the girder to hang from). The reason I ask if we can fix and hang from steel cladding is because when I had a look online, it seems pretty thin...has anyone had experience fixing and hanging lights from steel cladding? (exterior has a pvc membrane on the steel cladding- so drilling it wont make a hole for water to drip into) - another question that I asked my tutor but he hasn't replied yet is, when im adding grouping factors to containment - do I take the worse case and use that figure in my calcs ? (example - I have a run that passes through 3 different containment runs. one of the containment runs has 2 circuits in it, another containment has 3 circuits in it and the main containment "spine run" as such- has 6 circuits in it ... when working out my calcs, do I apply the Cg with the worse case containment?) I havnt come to working out calcs yet, im just making my routes...so I am aware that the 6 circuits wont all need to be added the calc, because a few of them have jack **** loading on them. Hope this paragraph makes sensecheers
Hi
I Cg is always a contentious area, strictly speaking its only for cable of the same size and loading, there are methods, whether your lecturer and cg will accept them im not sure, that said 2.3.3 of appendix 4 will support . A simple formula is given in app 4 2.3.3.1.
Cheers
Hi
Just to note, this statement refers to table 4C1
Cheers
Has anyone still got a copy of their project?
I've not done the 2396, and to be honest I'm nowhere near ready to do it.
But I'm bored pooless and wouldn't mind having a nose on a completed project.
Hi hope youre keeping safe and well. Any past papers for 2396 would be super useful especially when theres little else to do right now. Please PM me, thanks in anticipation.I have some of the 2396 past papers if that floats your lockdown boat?
PM me your email and I will send them over.
I made a mistake at first the cable and cable containment used and grouping numbers are all in the worksheets.Thankyoulooked over that - very interesting read. What do you guys think about using uni-strut (With uni-strut PVC lid) as containment for FP200? And would I class the ref method as trunking?
HI was wondering could you send me past papers if you have them pleaseHi hope youre keeping safe and well. Any past papers for 2396 would be super useful especially when theres little else to do right now. Please PM me, thanks in anticipation.
Hi Speeka,Hello All
Currently attempting the 2023 2396 design course & the project is a small library also. Does C&G reuse their projects? From what i have been reading in this thread it seems like the same exact project, with the same type of roofing mentioned along with the single DB in the intake room. There is no requirement for lumen calculation, along with heating & ventialtion & fire alarm which is being done by other designers for the project.
Im currently getting ready for the test which is in December & seem to be scoring ok on the previous test papers ive managed to get from the training centre, but there is little to no extra help, now the course is over & absolutely zero help from the centre with the project. Not the best training centre to be honest & although my lecturer was decent enough bloke, there's been next to no help after the fact & this is causing me some concern.
If anyone has any tips or examples of previous projects, this would be really appreciated.
Cheers.
S.
