Discuss Device randomly trips ARC Fault Breaker in the DIY Electrical Advice area at ElectriciansForums.net
if my brand new fridge is connected to a circuit with an ARC Fault breaker, and if the circuit has ONLY ONE OUTLET on it (the one to which the fridge is connected), then what are the most likely causes of RANDOM arc fault trips. It'll stay on for a week...then all of a sudden...it'll trip (even if the fridge compressor is NOT running). If the outlet is properly installed...and there are no issues with wires touching or anything...then is this most likely a defective breaker?
Tough one to diagnose
if possible, first try fridge on a different circuit and see if the fault moves to the new circuit.
if it does, then it may be a fault with the fridge.
Reply to Device randomly trips ARC Fault Breaker in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
I’m very confused I don’t know much about electric and looking for help. My TV, Microwave, and HVAC randomly turn off for a second then come back...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
