Discuss Dimmer led flickering in the UK Electrical Forum area at ElectriciansForums.net
Afternoon, i just replaced light switch with click vpsv140 dimmer switch alongside megaman led 40W bulb.
If i have the switch midway, bulb flickers and i can hear electrical buz. Tugg test, cables secure so its not a loose connection.
Switch all the way up/down perfectly fine. No noise whatsoever. Is this normal?
A lot of LEDs are not dimmable, even if it says they are on the packet
Connection not being made or unmade completely.
make sure the dimmer has a min. load < 5watts.
Reply to Dimmer led flickering in the UK Electrical Forum area at ElectriciansForums.net
I fitted a dimmer switch by daisy chaining the dimmer switch to a normal plug. The challenge is the light flickers at random intervals. If I take...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
