N
neil_ev
Hi all,
After rewiring a property the owner has been complaining of flickering lights on a lighting circuit in the lounge.
Sometimes when the dimmer switch is turned there is a slight flicker on the lamps.
The circuit has 5 wall lights on it with 2 x 45w halogen lamps in each (450w total) and a 1000w dimmer controlling it.
I have tried 2 different manufacturers of dimmer and still having the same problem.
Could it be that because the dimmer switch range is 200w - 1000w that the 450w load is a little light? (I know it's within the limits but sometimes these things can happen....?)
The customer is withholding all payment until this is resolved (understandable) but also questioning my competency and the safety of the the entire installation!
I am keen to get this resolved, so as there is a poor selection of high wattage dimmers was also wandering if it would be a decent option to replace the lamps with either LED or CFL and fit a lower wattage LED dimmer, which I have found are great quality.
Sorry to ramble on, and any thoughts are gratefully received.
