Discuss Dimplex XL18N tripping RCD in the DIY Electrical Advice area at ElectriciansForums.net
fluggy
Hello,
DIY requesting help with diagnosing problem
My mother's storage heater has developed a fault after turning it back on for winter.
It trips the Consumer unit rcd when power switched on.
Initially I thought most likely an issue with an element. I removed all 3 elements and tested resistance, one was 64ohm (ok) the other two were no good. So I got 3 new elements and measured those (ok). Fitted them and it still has the same issue.
I have also checked the wire from the wall switch to the input at the bottom of the heater.
Further to this if I turn the input charge stat down it clicks off and I can switch it on without tripping, when I turn it up it clicks and trips out.
I run out of time today and had to leave it, also being a heater on a timed circuit it only had power for a few hours in the afternoon.
Would this likely be a problem with the button cutout switch or the stat, would they usually cause that problem when they fail?
Do I just bypass them for a test only, by disconnecting and linking the switched live at the stat/cutout to see if it stops tripping the RCD
It looks like the stat and cutout have been superseded by an all in one stat/cutout kit. Don't want to buy it until I know its needed.
TL;DR
Storage heater trips RCD, new elements fitted, still have issue, could it be input stat/cutout.
Reply to Dimplex XL18N tripping RCD in the DIY Electrical Advice area at ElectriciansForums.net
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
