Discuss Do I have 3 phase electric? in the UK Electrical Forum area at ElectriciansForums.net
KarenF
Hi there
I am wanting to get a 22Kw car charger installed which I believe needs 3 phase electric. I seem to recall that our house has a 3 phase supply as the previous owner had a workshop in the garden with some pretty powerful machinery. How can I tell if it does have 3 phase?
Thank you in advance.
Hi there
If its on three phases you would see 3 cutout fuses below the CU. A single phase power supply has only one. :)
OIP.cvNsr1zJNMAEtssB5ZY-mQHaEK
OIP.VOhngrQHXvmiTd2l6j1SNAAAAA
Three Phase and Single Fused Cutouts
Should be easy to determine when looking at intake/meter.
Better to look at the meter than the cutout, there are many installations with a 3 phase cutout but only a single phase meter and supply connected.
2 phase supplies may also use a 3 phase cutout and single phase cutouts can have a second fuse installed to them.
I once had a client who had appliances burnt out on a two phase system caused by a DNO "engineer" pulling the neutral from the meter with the power on. This happened a few seconds before I arrived on the scene, and I found him still holding the wire in his hand in the dark, not having a clue about the implications of what he had just done.
Reply to Do I have 3 phase electric? in the UK Electrical Forum area at ElectriciansForums.net
I have been asked if I can wire a motor for a car lifter in a domestic garage, however the motor is 3 phase and only single phase is available in...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
