Discuss Do I need to add RCD protection in the Australia area at ElectriciansForums.net
S
sparkymatt1987
Right, the situation is I'm changing some faulty 12volt transformers for some downlights in a kitchen. The lighting circuit is not RCD protected. Now, I know that the switch wires are buried in plaster less than 50mm from the surface. Because I've worked on this circuit and have to issue a minor works certificate. Do I HAVE to provide the RCD protection or is it something I note down in the details of departures from BS7671.
Ok, say the lighting circuit was to be added to. Would it be my responsibility to to change the MCB for an RCBO. If it was a ring circuit then I know this would have to be done but seen as its a lighting circuit I'm not 100%
you could argue that the existing circuit has buried cable in a wall and as you have altered that circuit, the whole circuit should be RCD protected. i would only feel obliged to fit an RCD on a lighting circuit mod. if it was in a special location, e.g. bathroom.
Yeh as long as what you fit is up to scratch mate you'll be fine, can't go taking responsibility for previous sparks work from years ago....
And bringing that up to scratch could take an age lol
Thank you for the advise. I have my napit assessment coming up next Friday and don't want the assessor to look at my certificates and fail me because I didnt add RCD protection. Thanks again
Is a small job like changing downlights going to be a sufficiently "difficult" job for Napit to assess your competence? I'd say its maintenance which any tom, dick or harry, or indeed susan, could do
this job may not be for his assessment, just one where the assessor may pick it up from his certs.
It's not the job I will be assesed on sorry. I have a complete rewire to show the chap. It's just I'm told he will be looking through my previous test Certs and don't want him to see I've altered a circuit and the RCD type and trip times on the cert have n/a in them.
well, if he picks up on it, just tell him that the job was for a like 4 like fittings replacement and that if you had altered the circuit, you would have fitted RCD to cover cables buried in walls.. sorted.
Reply to Do I need to add RCD protection in the Australia area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hi there , Currently doing a college project where i need to select protective devices for the contract. I'm now at the point of selecting SPDs...
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
Evening all, If a socket circuit is not RCD protected via an RCD/RCBO and there isn't the option of fitting an additional RCD enclosure or...
6K
