Discuss does anyone own a fluke T140? in the UK Electrical Forum area at ElectriciansForums.net
i need to know because i have just bought a voltage/continuity tester (TEK950) and then sent it back because it couldn't (or i couldn't get it to) detect polarity in a single phase system. with the probes on it would just say L and an anticlockwise arrow on the display no matter which way round the probes were
the seller is now saying theres nothing wrong with it, it acts just like the fluke T-140 that does not detect polarity either. every other tester i've used can detect polarity, and when you switch the probes around the LED's on the display switch from left to right, indicating the polarity. so i'm surprised to find out that the fluke t-140 can't do this simple task
so if somebody can inform me if a fluke T-140 can detect polarity or not, i would be greatful thanks
Fluke T100, T120 and T140 all have a polarity +&- LEDs, the + LED illuminates if the tester body probe L1 is positive with respect to the remote probe L2 on a DC source and the - LED illuminates if the probes are swapped. On an AC source both +&- LEDs are illuminated.
[/QUOTE]
I think the best way is to view the Fluke T140 users manual - here is the link to it: http://assets.fluke.com/manuals/T100____umeng0000.pdf
I would also ask why are you looking at the phase rotation indicator on the TEK950 when you are carrying out a single phase test - or am I missing something here? Perhaps someone else who uses a TEK950 can enlighten us on how they carry out a polarity test with this meter and if the phase rotation indicator changes from L to R if the poles are switched?
I would expect the phase rotation indicator to change from L to R on a 3 phase test but not on a single phase test.
[/QUOTE]
I thought this had been explained above, but in summary:
It can directly indicate DC polarity via the polarity LEDs, but obviously the LEDs do not indicate AC polarity. Polarity can be checked in the normal way by measuring the line voltages with respect to earth.
i didn't realise the LED's were just for phase rotation, every other tester i've used, on single phase the LED's change according to polarity, so i just thought thats what they all did.
Reply to does anyone own a fluke T140? in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
hi Can anyone tell me where to wire the active and neutral wires to in this single phase electric motor
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Looking to use this brooks Compton motor as a replacement in an electric cement mixer. can anyone tell me if it is designed to operate off a...
