I get this problem a lot.
For example I have been doing some BS7909 work for conference & events people. Their clients are more regularly insisting that 7909 forms are filled in for each temporary install, this is to cover contract conditions with the venue. So they rock up with a load of distro's, dimmer racks, lighting, amplifiers, video equipment and a whole load of laptops. The problem with all this gear is it has functional earths. So, if they're running a distro with a single RCD and multiple MCB's, they are on a no show from the get go. On a piece of string is a key, this key fits a switch on the distro that bypasses the RCD. Problem solved. Unless of course you want to comply with BS7909 which insists that all outlets less of 32A or less have 30mA RCD. The also use commando plugs for everything, and these are in and out every day, so poor contact is an issue and that mean Zs' go through the roof, especially as they use miles of chunky flex without ferules. They want me to sign a form, for their client, to say it complies with BS7909. I've checked the install, it doesn't.
As the professional they've hired in, did they hire to sign the form for them regardless or to help them meet BS7909?
I decided the latter and I gave them the facts, showed them where they didn't comply (obviously i quoted the regs from the BGB, felt like my old lecturer!) and gave them some reasons why they currently couldn't and how they might, if they really wanted to. I had a positive response, and i'm happy about that because it's good work.
There are some simple things and some stuff that they don't want to do but realise they'll have to, if they want to comply. As the guy signing the form to say it complies, it has to comply. People do die from shocks and the events industry is a high risk area, if there was ever an incident it would be high profile and damage my clients business big time.
So, do I always follow the regs, absolutely if i'm signing to say it complies. Same for Part P and EICR's. If it's a little job where getting everything to comply would be completely impractical, I can always fall back on that little thing in the regs where it says something along the lines of, and i'm not quoting directly: "Well mate, your house is no less safe than it was before".
I think using good judgement and interpreting the regs effectively is the key. Shoot me if you think I should burn in the fires of hell for my blasphemy.
Guess we all bend them when necessary but hopefully we have the knowledge to do so only when we can make the judgement that it is safe to do so as at the end of the day no install circumstances are the same and you have to make a judgement
