Hi all,
I replace about 30 lights from 2D to led, I'm under this impression I don't need to issue a certificate for this as it's only maintenance, am I wrong because the company are now chasing for a certificate
Many thanks
Take a look at chapter 63. You can use a minor works for change of current using equipment. That’s assuming you’ve changed the light fittings.
You are not wrong as it is like for like. However it is sage to at least offer a minor works and test Zs etc. I replaced 600 x 600 fluors for LED and found 89v on the earth just doing routine testing. Always wise to check imo.
To abstain from superfluity may render one's discourse bland and barren, to add emphasis by lack of brevity may be preferred, but one would not wish to categorically state that your communique was without merit, as this may cause one to veer away from factual statement.
Alt: Yeah you are right, but it does add emphasis;)
surely you are well qualified to write the 19th ed. if you start now with a thesaurus of gobbledygook , you should have a draft ready in time for the release in 2021.
Parsley, sage, rosemary and thyme...
Sage, wise
Sage, a wise man
Sage, a popular online payment system/accounting package
I love the English language!
It's a bu**ger for foreigners to learn, though...
Incidentally, while many folks ridicule the use of Microsoft Publisher, it has many in-built Certificates...or just design your own!
Sage, wise
Sage, a wise man
Try "The Chaos" by Dr. Trenité. Warning: Frenchman said he preferred six months hard labour!
For example:
Hear me say, devoid of trickery,
Daughter, laughter, and Terpsichore,
Typhoid, measles, topsails, aisles,
Exiles, similes, and reviles;
Scholar, vicar, and cigar,
Solar, mica, war and far;
One, anemone, Balmoral,
Kitchen, lichen, laundry, laurel;
Gertrude, German, wind and mind,
Scene, Melpomene, mankind.
Does this work need a certificate?
allybally69,
Richard Burns,
