Guys
I have 2 DOL starters which share the same supply for 2 toilet extract fans I have a selector switch wired up and and a set of auxilliary
normally closed contacts on each of the DOL starters to prevent both fans running at the same time. If possible could some one point me please in the direction of a diagram to allow me to wire the fans for automatic changeover in the event of the duty fan tripping out on overload as there is no nanatural ventillation in the toilet core .
I have 2 trip lamps to indicate which fan has tripped and I have wired up the DOL starters for automatic changeover via the overload on the dol starters connections 96 and 97 my problem is the way I have wired it is that if I set fan 1 as duty, the trip lamp on fan 2 is on even though fan 2 has not tripped I know why the lamp is on but I dont have the intelligence to solve the issue that is why I am asking for help from the forum members
Thanks Dimspark
Thanks Dimspark
