Search the forum,
Discuss Domestic kitchens in the UK Electrical Forum area at ElectriciansForums.net
That’s how a lot of new builds are done. Although I think there’s a few on here who don’t like using 20A DP switches protected by a 32A ocpd.
Never understood that myself as a standard domestic appliance would never draw anywhere near 20 amps. I think they assume that the DP switch would have 32 amps flowing through it rather than just the supply side terminations taking the current.
20 amp DP switches are used on the grid for isolation/maintenance purposes only, nothing to do with having only 20 amps max through the switch or whatever as installing a fuse or a fused connection unit would be pointless considering the appliance plug has a fuse inside it.
Some appliance manufacturers specify a 16a over current device. So if you are strictly following the M.I then putting the appliance directly on a 32a ring is not correct.
of course the appliance will work hardwired directly to the 32a ring and I have done this on occasion but technically it’s not correct unless fuses down to the correct rating
The plug has a 13 amp fuse in it so that’s not technically accurate, more like the instructions cater for the European 16amp socket arrangement where there is no fuse inside a plug.
The grid switches in many of the late 2000s new build flats I've been in recently all have fusing at the grid switch - but I think when new they had appliance outlet plates at the appliance so no fused plug.
That may have been to avoid having to put them on the RCD side in the CU, or because they thought it was neater - but most have since been replaced with single sockets since they're almost all rented and tenants prefer to plug a fridge in....
Out of interest, in what circumstance would you not need to use 2.5mm on the outgoing side?
When the cable is
a) Adequately protected from overload by a downstream device and/or the nature of the load. ✔️
b) Adequately protected from faults by the upstream device. ✔️
And even if you didn't need to, why wouldn't you?
To avoid waste, and have an efficient design.
Looked at the other way, why would you use an oversized cable?
Reply to Domestic kitchens in the UK Electrical Forum area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
UK Strange
I am decorating our bedroom which only has 1 double socket in it. We have been using multiple gang sockets which are untidy and a trip risk, so I...
