Discuss Double oven tripping electric in the DIY Electrical Advice area at ElectriciansForums.net
Murrdock
I have just replaced my old double oven which was about 10 years old with a new model as whenever I used the top oven it tripped the electrics. However the new one is doing exactly the same. Bottom oven works perfectly as did the old one, so question I have, is the oven faulty and it’s a coincidence that it has the same fault or is something wrong with my wiring? Need to call either an electrician or curry’s but not sure which one i start with?
I hope for your sake that you called an Electrician and not Curry's?
Reply to Double oven tripping electric in the DIY Electrical Advice area at ElectriciansForums.net
I have just replaced my old double oven which was about 10 years old with a new model as whenever I used the top oven it tripped the electrics...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how my oven is currently wired up, followed by 3...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi, I bought my Zanussi ZCV663MWC cooker ten years ago, I replaced the top element four months ago and its been fine until now. When I turn the...
