C
CenterSparks
Hi, First of all im not a fully qualified sparks yet, so I may be missing something really simple. Bacially in out bathroom we have 6 Halgoeon Downlights. For the past 2 years thev'e been fine but over the past few months they start to flicker and buzz abit like they're surging every now and then. Just recently it has gotton really bad to the point they dont stay on more than 20 seconds before going off and on again. The buzzing seems to be coming from the pull chord which I found strange, and when the chord is pulled off and on again the lights temp. fix themselfs. You can hear the buzzing get louder as you touch any part of the pull chord. Ive checked the connections and they seem fine. I was wondering if there was somthing in the pull chord mechanisim that could be faulty as there is some kind of electronic bit in the switch it's self by the looks of it. I though it might be the transformers at first but im not so sure now. Cheers for any help . . .
Replace the pull cord there not expensive
are they 240v or 12v if so it could be the transformers
I would say that if all the lights flicker and go off then changing the pull cord would be the answer.
