robd
Evening all, Got a site where the spec is to fit downlights in the bathrooms, ensuites etc. Have been fitting LV fittings with transformers but getting about 1 per house where the transformers are overheating due to dropping down into the insulation which is some sort of recycled newspaper pulp stuff. Obviously this means I have to go back and am wasting time, wouldn't mind the odd one but it's nearly every house at the moment.
Obvious answer seems to be mains voltage IP rated, cost allowing, the ceilings are high enough to be out of the zones, I've probably answered my own question here :clap:but wondered if anyone else had any ideas of a way round the bloomin transformers problem! Cheers
Don't fit them,simples
A bit of 3 x 1 stretching between the joists above the insulation with the trannys screwed on to those?
use 230v ip rated downlights with led lamps. jobs a gud un.
Cheers Trev the lead on the transformers not long enough to clear the insulation though, something like 5 or 600mm of the stuff up there
Yeah a site on a price though, prob a bit pricey for this particular job. Cheers though.
On the LED subject a customer showed me some LED's they bought from argos the other day £5 a pop and would retro fit into most fittings I reckon, seemed cheap to me, don't know if they're just rubbish or what
Yeah there's a lot of cheaper ones about now, but tbh I haven't seen any that have been up to much good at all. Bit of a you get what you pay for kinda thing with those
