hi all im looking at buying a machine to help me unblock drains in domestic houses in the uk , i have a small ridged k45 af5 small drum machine that i use on 32mm and 40mm but was looking at buying a kranzle k10/22 ts pressure washer and using the kranzle drain hose on it to remove blockages in 110mm drains , and wc pans , has anyone got this set up and does it work ok ive seen some utube clips and seems positive just dont want to waste 900 quid!! ive looked at the ridged flexshaft but worry it might get stuck in 32mm pipe or damage old plastic solvent weld . any advice would be great from drian unblocker people
many thanks
Continue reading...
drain unblocking equipment what to buy ?; Plumbers Forums
Plumbers Forums
Thread Tags
Tags Tags
None
luckyme,
