Discuss Drilled through cable in wall, can I fix? (Photo) in the UK Electrical Forum area at ElectriciansForums.net
Sam22
Drilled through cable in kitchen wall, tripped the fuse box. Switched back on and everything works apart from the cooker hood.
I've called electrician and explained, given me a quote of £120 plus VAT. Is that reasonable?
Is this something I can fix? If so, how? I have basic electrical skills (i.e I can install a new light fitting, install a dimmer switch, change a plug, etc...!)
Sounds a bit expensive to me. Not a difficult fix, but need to use the right parts for the job and also test the work afterwards.
Seems like a reasonable price dependent on how they plan to rectify the fault.
Just be aware, now that you have re energised the circuit, that bare copper you could see may well be 'live'. Also, if you've managed to cut through the earth, then there is also the possibility that the cooker hood is no longer earthed.
first, what is going to be fitted where you cut the hole? then, is the any slack on the cables?
Could I turn the power off, strip back the cable at the damaged point and a connector block to link the 2 damaged ends back together...?
Have it repaired professionally. That method is not the way to do it properly and safely. Its not worth the agro, if you get it wrong then it could end up costing you more in the long run.
No, this would not meet the requirements of the electrical regs.
No, that would be somewhat dangerous.
The joint needs to be made in a suitable enclosure or the sheath suitably reinstated. The joint must be made in such a way that it may be classed as maintainence free if it will be inaccessible in the future.
The circuit must be tested to ensure that it is safe to be re-energised.
You should switch the circuit off until it is repaired, the damaged cable presents a risk of fire and of a potentially fatal electric shock.
and there's no VAT on my price. the government don't work for me, so why should i pay their wages?
Thanks for your replies. The large cut out of plasterboard is just what a did so I could see the damage, I'm only putting shelves up so the shelf brackets could easily go slightly to one side, just my luck I've gone directly where a cable is.... Should have known, there's a switch directly beneath.
Is there any other connection I could make that would be suitable? What about wago connectors? Or junction box in plastic casing?
yeah, but in oxfordshire you have lobster and wine. up here we survive on a wrights pie and a pint of ale.
Because the pads down here are so expensive, we have to survive on dripping and dirty water. I draw a line at Paul Masson plonk though :)
If you plan on leaving the joint easily accessible then its an option, assuming there's enough slack and can be terminated correctly. But If you intend to plaster back over the joint then no they would not.
Reply to Drilled through cable in wall, can I fix? (Photo) in the UK Electrical Forum area at ElectriciansForums.net
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
