Z
zerozero7
Hi all, need to replace a failed 500w halogen PIR floodlight. This one was a dual output model that had an adjustable dimmer on the PIR housing for setting night time dusk to dawn illumination but switched to full brightness when it detected motion.
Has anybody come across an LED floodlight with similar functionality?
If not, which alternative route could I take?
Two separate PIR floodlights with the PIR configured differently would probably do it or even one floodlight on a separate Dusk/Dawn sensor (with timer so switches it switches off at 2am, Steinel 3000). This floodlight could then also be switched on by the slave output from the second Motion activated PIR floodlight?
These solutions are getting costly as I want to use a reliable high quality brand (Steinel, Luceco???) with a high wattage to cover a larger area. The original floodlight was only £21.99 (about 10 years ago).
Any other suggestions welcome
Thanks, Gary
Thanks, Gary
