AFAIK Holland never used this voltage significantly, so it's probably transformer-fed for the convenience of tourists. Historically, like a few other European countries, they had 3-phase 127/220V distribution systems (i.e. 220V L-L.) If this was delta, as it often was, single-phase customers got two lines with 220V between them. This is one of the reasons many European plugs are not polarised; there was no polarity to speak of as both wires were lines (DP fusing was standard). In star-wired areas, customers were served with 127V L-N. If you look in the back of older electronic appliances with voltage selectors, you can sometimes find a tapping for this voltage. But all these supplies were converted to 220V by the 1970s as the 220/380V supply became standardised.
France had quite a lot of 110, but not using the US flat-prong plugs.
