Discuss E-line consumer unit din rail in the UK Electrical Forum area at ElectriciansForums.net
Done an EICR this week on a small flat, no issues other than the CU, E-line dual RCD, plastic, roughly 10 years old. MCBs didn't seem to sit right with cover on, in fact there was a blank missing that I was going to replace and then realised why it was missing, because the gap was just a bit too small. Looking closely with the busbar cover removed, it appears there's no proper din rail at the back for the devices to fix too, other than at the far left for the main switch and the far right for one of the RCCBs. Basically, in between, there's only a top half of a din rail for devices to hook onto, but no bottom half for the spring clips to fasten to, so all MCBs and the other RCCB aren't properly secured at the bottom, other than by the busbars clipped to the base. The cover when it's back on obviously prevents them being able to move as freely but they're still not fully secured and it's difficult to get the cover back on as they aren't quite sitting vertically.
I'm not sure if there's part of the assembly missing, or if it's an unusual style of mounting devices that E-line uses and the MCBs (which are CPN) aren't compatible. The cover is a struggle to get back on properly but when it is it's not obvious the devices aren't properly secured. There's no sign of any thermal damage but would appreciate some thoughts on this. I'm personally reluctant to give it a C3 as I think there's potential over time for connections to loosen if the devices can me "jiggled about" even slightly.
Reply to E-line consumer unit din rail in the UK Electrical Forum area at ElectriciansForums.net
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hi all! I'm not a spark but know enough to be able to install off grid solar etc. I've just purchased a new house and have noticed the consumer...
5K
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
