you dont want it sleaved as part of a flat twin....the CPC runs between the live conductors yes...
so will intercept any breakdown in insulation between live conductors yes...
this is the reason the CPC in twin isn`t sleaved/insulated....
not for cost reasons...as was debated a while back in here...
Valid point, it would be handy all the same to abe it slaved, but you are quite right.
Flex is nice but then you need to add little fiddle ferrules into the ends, admittedly I find it quite satisfying adding the ends on, weird I know, just think it looks tidy other than serving a good purpose!
We only use tri rated in control cabs, I know what you mean, crimping the ferrules is the most satisfying part!
You normally make a good valid argument for your reasoning , but the bit about insulation breakdown seems too bizarre even for you.
It maybe satisfying but you get the extra pleasure of complying to a Reg! :-)
so...if the cable is penetrated by screw..or nail...would this constitute a breakdown in insulation?
Im going to get some big Klauke K28 crimpers when I can justify them so that I can crimp 16mm tri and twin ferrules in consumer units, I put nice ends on the end that goes into the earth and neutral but sometimes you find a board that's just got bare strands, most annoying!
I suppose you could look at it like that yes, I like to think I have at least tried to comply, it then makes me feel better about the things that don't quite comply ;-)
Yes is is would, but what about 3 core and earth? No protection there if it breaks down away from the CPC? What if it's not connected as a CPC surely that's even more dangerous if that's the purpose of it?
