L
longboat
What is it's primary function?
Discuss Earth sleeving in the UK Electrical Forum area at ElectriciansForums.net
Tell me about it. I ain't gonna lie, I'll be pooing myself slightly! I've spent hours making notes and practising speaking for more than a few seconds without swearing! I really hope we come across well and that we make good, clear and consise points. Unfortunately I fear there won't be enough time to bring to light the myriad of issues surrounding the current situation, but hopefully we can address some of the more important ones.
I would say identification only as the sleaving gives no form of protection as is only thin and flimsy.it would be nice if twin and earth had the earth sheathed as you would not need to sleeve it, I know it's all money and size etc, would be nice though.
I'm sure a man of your capable abilities will breeze it!
you dont want it sleaved as part of a flat twin....the CPC runs between the live conductors yes...I would say identification only as the sleaving gives no form of protection as is only thin and flimsy.it would be nice if twin and earth had the earth sheathed as you would not need to sleeve it, I know it's all money and size etc, would be nice though.
If you feel a bit shaky and intimidated
so will intercept any breakdown in insulation between live conductors yes...
this is the reason the CPC in twin isn`t sleaved/insulated....
not for cost reasons...as was debated a while back in here...
Flex is nice but then you need to add little fiddle ferrules into the ends, admittedly I find it quite satisfying adding the ends on, weird I know, just think it looks tidy other than serving a good purpose!
what makes you think that Dillon?Have you been on the crack pipe Glenn?
so...if the cable is penetrated by screw..or nail...would this constitute a breakdown in insulation?You normally make a good valid argument for your reasoning , but the bit about insulation breakdown seems too bizarre even for you.
well...Your sort of being polite tonight !?:leaving:
It maybe satisfying but you get the extra pleasure of complying to a Reg!
Reply to Earth sleeving in the UK Electrical Forum area at ElectriciansForums.net
