all well and good til wet-pants comes along, fits some plastic pipes, thinks ( i know, a rare occurence) this cable is redundant, rip it out for scrap.......
Which is a VERY good point so sharing the MB and EB is not a good idea.
Wonder what his scheme has said?
I doubt they will have an answer, hence the can of worms comment earlier, it's a crappy method and I would avoid it, however if the cable is unbroken I think they will find it hard to condemn it, that said I have not got access right now to the Regs, I would love to read up on this though, never come across it before as I would never do it myself, however as mentioned earlier under the circumstances it's probably okay and I could sleep over doing it. Bet theres a reg somewhere which says it can't be done though
This situation of "Earthing" will be difficult to met regulation 542.4.2 but does the scams care I'd say no "as it's only a guide" so that's why the standards are dropping fast. In my book it's not acceptable and yes it should go directly to the MET and the bonding conductors taken separately to other services. Another bodge job in my book to put in the snagging book.
- - - Updated - - -
Biff will know the answer no doubt
As above, install today TT system to which brand new rod in garden with 16mm coming from it, but on way back to board picks up both gas and water as right at front and heads back to board which is at the rear of the property. I'm changing a DB to the install, a certain local company did the earthing and bonding when they came to install a electric cooker.. Now then is this permitted and acceptable? E45 the earthing guru may be able to help
Have you called your schemes techical help line?
Hi,
Bonding would normally required to be connected at the point of entry into the house ( ie within 600mm ). In this case does the connection take place at the point of entry or some distance external to the property?
Regards.
As far as i'm concerned the MET/EMT are there for a purpose. Which is a ''SINGLE'' position, where individual earthing and/or bonding conductors come together. Joints along a single earthing conductor does not meet the criteria definitions of either a MET or a EMT!!
But what about when testing? Would not parallel earthing of the water / gas pipes make an impact on readings obtained.
- - - Updated - - -
See post 22
- - - Updated - - -
blimey, NICEIC agrees with Eng54. that's history, man.
I think they are right, but still think it is safe if the core is unbroken and continuous, however this time I agree with them about it
