Discuss earthing of steel trunking in the Commercial Electrical Advice area at ElectriciansForums.net
hi guys just bare with me please still learning lol! if i have connected my steel trunking to the metal frame work via bush and cuplin and and the steel frame is earthed and i can prove continuity from my trunking to the steel work do i still need to earth my steel trunking and also do i need fly links to my lid thanks in advance ?
Agree with Dave sparks on this one as should be well fixed with bolts to the DB with a Paxlin segregation between.
Yes, agreed also. I had read the OP as being fixed to structural steel.
Personally I would use copper links between lengths of trunking because it's the accepted practice here (even though they're not cheap).
I have never seen the point, you fix the lengths together with steel plates then add a tiny bit of copper under two of the screws.
Reply to earthing of steel trunking in the Commercial Electrical Advice area at ElectriciansForums.net
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
Hi all, Figured I'd come straight to the experts with this one because I don't have a great deal of electrical experience. I'm a designer at a...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
My spouse was breaking up pulled pork in the Instant Pot using metal forks while the Instant Pot was plugged into the wall, but not on/heating –...
