Discuss Earthing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
Peter Woodford
Hi chaps
A customer wants her old fuse board change but there is no earthing to gas and water have told her this needs doing but she does not want floorboard carpet pulled up do I just make a not on cert that customer didn't want it done
Cheers
DITTO !
Dont do the board unless Main Earth ..and Protective earth to gas & water are in place....
...would also advise P.I.R before commencing ..if not already done so { Dual RCD Board ?....Borrowed neutrals on lights etc ?
I have already said I can't carry out works unless this is corrected but just wanted to make sure. Just hope nobody else comes along and changes the fuse board for her
Peter, in all honesty and please dont take offence, but this is the most important part of ANY installation and its a question that you really shouldnt have to ask!
If they wont pay for bonding installation or upgrade then it is in your best interest to walk away.
After all, its your name on the certificate and you in the dock if it ever came to court.
Of course, you could always price for the CU change and include an amount to cover the bonding.
as above. dont even consider doing it without main earthing and bonding in place :eek:
thought you just passed your nic assessment:confused: you shouldnt be asking questions like this if you have :eek::eek::eek:
Also agreed ! imagine if this job is one of the ones the NIC chose to inspect on an annual ! :( sods law it will be ! Id remind her of the dangers that could happen and show her the regs book and if she wants she can call Building control or NIC etc
Reply to Earthing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
I'm getting an old fuse board upgraded in an office block. The electrician has just told me that most of the circuits don't have earth cables...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
