Discuss Economy 7 - need confusion clearing up please! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
We have an Economy 7 meter and tariff.
There are 2 separate fuse boards and one meter with the dual rate on.
Am i right in thinking that ANY electricity we use at night will be cheaper as the meter has a 'timer' to switch to the cheaper tariff? If so then why is there the need for a separate economy 7 fuse board?
We have storage heaters that run off that board as well as the 'normal' board - presumably they store from the night board and can be boosted from the day, but if ALL electricity is cheap overnight then why the need for a separate board?
If someone could let me know i'd appreciate it!
Your storage heaters and the board they come from are timed or remotely controlled to only come on at night. All electricity is cheaper through the night, but you don’t want your heaters powered up during the day on expensive rate.
Sometimes the e7 board and normal are combined into one board, but they take up a lot of space and still require 2 sets of “tails” - the thick cable that connects the board to the meter.
The separate board easily allows the items powered during E7 times to be on only during those times. The whole board is switched (probably in your case by the meter). If you have just one board then each piece of equipment for E7 would need to have its own timer.
Some arrangements do mean only the E7 items are charged at the E7 rate and the main board at normal rate but your description does not sound like that (it is fairly old school now).
You probably have something like the below diagram
When E7 was first introduced, two meters were required.
Normal meter was black, off peak meter was white, and the two meters were set at different rates.
Both meters could technically supply power at any time of the day, but the white meter was connected to a time clock which would only allow the power through at the set times.
Later a single dual tariff meter was designed, which had two connection points as per the drawing posted by Richard Burns. This meter could be remotely controlled by the supplier to turn on or off the off peak supply.
The introduction of such meters allowed for new tariffs such as E10 to be introduced.
The E10 tariff allowed the supplier to offer an extra 3 hours off peak during the evening in addition to the standard E7 times of midnight to 7am.
I can’t recall the times the extra 3 hours would be supplied during the evening, but the intention was for the supplier to choose hour slots where there was cheaper electricity.
So you could have supply from 7 to 8, 9 to 10 and 11 to midnight, 7 to 10, 9 to midnight or whatever combination the supplier deemed would be cheapest that day.
Many suppliers now offer a cheaper tariff for all electricity consumed at night, but still offer to switch the the second supply on and off remotely, so storage heaters are not on continuously.
In other cases, a time clock is required to control when power is delivered to storage heaters.
Yes, during non E7 hours the top left board should be off and all power consumed by the lower right board will be at normal day rate.
When E7 hours start the top left board will be powered up and anything connected to it will start (if switched on). The meter will then be recording the power consumed by both boards on E7 night rate.
Thanks Richard, good to know. There’s also an immersion label on the E7 left board and right main board but my immersion only has one input through a timer switch....something for an electrician to look at I guess. I’ve read that most e7 immersion tanks have a lower e7 immersion and upper normal. Ours only has normal and as far as I can tell.
Thanks again for help.
May I ask where the "2 rate digital meter" is usually located?
Otherwise known as "the electricity meter" - for a private house, in a box outside in or on the wall somewhere, or indoors by the consumer unit. For an apartment/ flat, generally in a cupboard in a corridor on the same floor, sometimes basement or a central location.
Thanks for replying!
In fact its a little observation* that brings me to this thread. Let me start just from the setup we have.
Our flat is on 4th floor. There's a meter room on the G/f hosting all the meters for the flats in the building.
Our meter looks like this, with three different readings alternating:
Inside our flat there're two fuse boards. I assume one is for OFF peak and one is for ON peak, judging from the connected appliances:
* Observation - we have a Gledhill Torrent thermal store, with two immersions, one connected to a OFF peak socket and one to a ON peak socket. Interesting enough, the OFF peak immersion will turn itself ON during daytime. This can't be right?
When we phoned Bristol Energy the provider, we're told our meter isn't a "Smart Meter", and scheduled ours for a upgrade.
Will that make any difference to our bizarre observation?
Where the meters are located, is there any other boxes seemingly connected to the meters if so can you take a photo and post here?
There may be a separate time switch which has lost the correct time and is switching on early or if the meter has a built in time switch that may be wrong.
And re, will a Smart meter make any difference, given the limited knowledge of E7 and Off Peak installations that the average "Smart Meter" installer appears to have, it's quite likely you'll end up with no E7 working or it working all the time or some other variation.
No offence intended to the few knowledgeable "Smart Meter" installers, who usually end up sorting out the mess left by others.
Some tariffs have an afternoon boost.
From memory usually some time between 2 and 4.
Do your storage heaters charge at the same time?
I suppose another way of checking this would be to race to the meter cupboard when the offending immersion comes on, and see which rate is clocking up on the meter (assuming the water temperature is cool enough to trigger demand)
Around here storage heater isolators almost always have a neon, I'm not sure if that applies in deepest darkest Englandshire too though. :)
E10
Googling reveals that Bristol Energy were (one of the few) willing to take on some E10 customers who had an E10 set-up and wanted to switch to them, and they would bill as if E7 (and call it that).
But I gather Bristol Energy is now in liquidation, so no idea where this will lead.
Edit:
The sale to Scotland-based Together Energy, which is 50 per cent owned by Warrington Borough Council, safeguards 110 frontline workers who will transfer over to the new company.
Service for customers will continue as before after Together also bought the Bristol Energy brand and systems, along with 155,000 residential meter points.
THTC, E10 E7 I can't keep up or make head nor tail of the different tariffs. :D
If the off peak is controlled by a teleswitch or similar the off peak times vary.
Long and short of it People not on Economy 10 also get a period mid late afternoon whether this is only THTC or THTC and E7 I can't remember. :)
Reply to Economy 7 - need confusion clearing up please! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
if a house has economy 7, off peak board and on peak board. and where the meter only energizes the off peak board during the night for the storage...
I recently got my flat rewired. It had old storage heaters and we plan on putting modern storage heaters in. The way the electrician did the...
Yesterday moved my Mum into her new bungalow. The Hortsmann had been off for a few months I suspect. The boost worked, but nothing happened...
