Search the forum,
Discuss EDF refusing to fit a meter until signed off?! in the UK Electrical Forum area at ElectriciansForums.net
Theres no reason not to fit the meters as long as your tails are not connected
If its that desperate call eon up or just connect the boards anyway unmetered
Experienced this before, and had to connect up a single socket radial to the CU, and fit the tails etc, they then happily connected it up, but they did fit an isolator as well.
Cheers.................
I will assume that it is because the supply is Tncs and that is what is making them overreact,perhaps he has heard of things like bonding and such
It seems to be pot luck
I just had a meter fitted to a house where the supply is also Tncs,I mounted a temp board and a KMf ( in their cabinet as usual ) and stuck an earth rod in,I left a certificate in the cabinet for them
I had no jumped up meter monkey,(I must have had a spark fit the meter) When The house is ready,its just a matter of swapping over
Eon/EDF rebooked.
Oh no, says Mr Regional EDF manager jobsworth yesterday, can't connect up until the job's finished. What?! Reason he claims is that their EDF meters don't have the little iso switch on them, and that it's impossible for the domestic side tails to be fitted after they've left as that involves breaking their seal. Wouldn't budge on the Left-side / Right-side meter tradition and insisted that they have to fit the domestic tails...as such, they have to be satisfied of the risk/certs/responsibility/CPD etc. And he wasn't going to do that for 'temporary' boards (despite these being proper job, robust and RCD protected made for purpose boards). So I then ask him how it might be possible to any electrician to issue a cert with a Ze on it without first being connected.....he glazes over and says well, you'll have to put some rods in and make it a TT first then use the PME afterwards.
He then also started muttering about building site regs (incorrectly, I might add) and said in response to my asking, that as far as he's concerned it's a building site until signed off by the BCO.
This is simply ridiculous, the developer has gone ballistic (understandably) and I'm trying to dodge the cross-fire!! I'm ALMOST tempted to fit a couple of meters myself (so as to be able to record usage and be honest) and then remove them afterwards!
- - - Updated - - -
Eon/EDF rebooked.
704.411.3.1 doesn't apply to this site in so much as it's all plastic - not a sausage to bond anywhere, so that's not an argument either!!
Speaking to a mate who works for western power he said if you request a double pole switch to be installed they are obliged to put one in free of charge as a safety measure
That's useful to know, thanks, but I think the problem is defining who 'they' is! I've been told by meter fitters in the past that they can't fit an isolator to the right side as that infringes on the consumer side which makes it liable to part p and they're not a part p installer! But install to the left of the meter and it's in no-mans-land as the DNO's responsibility runs out at the bullet.
The ESQR make it a requireent that the supplier ensures that any installation complies with either BS7671 or ESQR, before allowing a connection to be made.
The usual method, is to provide an EIC, stating the installation complies with BS7671.
However that being said and done, the supplier is still allowed to refuse connection on the grounds of safety.
Reply to EDF refusing to fit a meter until signed off?! in the UK Electrical Forum area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
DNO ripped out antique main incomer/breaker .The guy hated us and himself and everyone else by the end of the job ! . Client going to contact...
This is a strange one, my neighbour is a bit mad, he had a largish extension built in about 2015, the builder attempted to do everything including...
Hi All On the 2nd November an EON contractor attempted to fit an electricity smart meter at my address. He was unable to do so because the...
6K
Hi all I have a customer who wants a smart meter .. they are with edf .. The existing meters ...1 day rate , 1 off peak ..plus mechanical time...
5K
