I like the MG board because they have the slide switch to isolate the breaker which I think is quite good, unless you forget to slide it back after you fitted the cover
I have a rewireable DB im testing, install about 50yrs old but pretty good as never been touched, only real problem is the two Dbs (one above the other for power and lighting) as fuses too big for cable sizes etc.
I am going to advise a new DB incoperating all circuits, its a doctors practice now, so wouldnt want RCCB's incase of nuisance tripping, but as cables are burried in walls is there anyway i can avoid RCD protection on lights etc? and i could rcbo the sockets etc.
being under supervision and management would mean no one is going to be drilling the walls on banging nails in!
Have started using a bit more Eaton gear recently, used to be MG/Schneider all the way but again, it's getting hard to come by round my way. Neweys hold Eaton in stock.
...., its a doctors practice .....
I wouldn't be so sure about that. Doctor's practices are usually run by an office manager type, or even the doctors themselves, who in my opinion would not understand about building work and electrical installations.
Hager 3ph DB's for me all the way, nowt better!! and the ones with the glass doors look the puppies!!
I've priced up for boards today, and the cheapest is wylex. Then it's hager. MEM and MG about the same. I've offered the client a choice, and he's happy to go with MG, and I'm a happy boy!
Well the way i look at it is the manager of ther 3 NHS practices called me to test, and no one ever carries out work there themselves, so i would class that as being under supervision of skilled or 'Instructed person'
As per regulation 522.6.102
It would be over the top to fit 22 rcbo's just to change the DB, although i would RCBO general sockets, kitchen and toilet hand driers etc but leave lighting and certain power on MCB's. Its still a lot safer than it is now with the 3036's and incorrect sized fuses ive found etc.
