well, I had this exact same problem at a place last summer - drove me potty trying to figure it out. Bloke was digging a trench to install some new drains and rang me saying he was getting a shock from an old buried oil pipe. Sure enough, definite shock to be felt, but couldn't register any sort of proper meter readings. I made an assumption that it was maybe coming from the boiler inside.....couldn't find anything at all wrong, stripped thw whole lot apart, ran all the tests and a big zero. I stood up, and leant against the stainless steel sink in the utility room - whack! There it was, on the sink. On the taps, on the bonding...... but not 230v 50Hz - you could feel it but the meter just wouldn't register (and yes, it was proved good). It was only went I went really belt and braces and started to pull apart every circuit in every hole in every bit of the place that I found it: An electric fence energiser!!! There's one of my very first threads about it on here somewhere. They had a stupidly long electric fence around a duck pond and the grass had grown up the bottom, making a permanent circuit to the energiser. The fence ground rod was further away than the house TT rod, but the energiser (in a stable block) had been miswired so that the fence ground was accidentally wired back to the main earth.................and all the way back through the ground and up into the house!! You only felt it in places where you came into contact with the bonding - basically the kitchen. Rewire fence energiser and fit the fence with it's own rod and problem instantly went away!
