Discuss Electric underfloor heating for a church? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Pretty Mouth
What are your thoughts on using electric underfloor heating as a primary heat source in a church?
It's a typical old church building - a couple of hundred years old, very high ceiling, masonry walls, single glazed stained glass windows, no insulation anywhere. You know the sort of thing. Cold, and difficult to heat. The wall heaters aren't very effective, as the heat just rises up away from where it's useful.
The church representative suggested UFH, the idea being that it would produce heat where it's needed most. The church is used sporadically, so it wouldn't be heated all the time, just when needed.
Just wondering what you all think of the idea? Has anyone here done the same, or heated a similar space using UFH? What about warm up times, and efficiency?
A Church I work for had all the old radiators removed and 2 air conditioning units installed that heat in the winter and cool in the summer.They certainly warmed the place up and that had very high ceilings.I cannot see UFH working in such a large area.
The IR radiator sort might be good as they offer "instant warmth" before air has to heat up, etc, so if church used only for short periods at a time more economic.
But longer use a heat pump, either for UFH or air-con working in reverse to heat (as suggested above) is going to get more therms per £ than other methods.
Hmm, all electric heating in that sort of building - I can't help thinking it might be just as cost effective as getting a load of fivers from the bank and burning them in a brazier 😱
We have a wet system that's been cobbled together over time - starting with the old cast pipes down both sides, and most recently with some fan coils added. It takes the boiler half an hour just to get the (guestimate) 100 gallons of water in the system up to the point where the pipe stats in the fan coils come on.
As they were installed, the fans were far too noisy, so at the start of the service they'd be switched off. At this point, the water in the pipes isn't hot enough for them to do all that much, and the cold draughts coming down off the windows made everyone cold rather quickly. We've done some experimenting, and by changing the stats for a higher temperature, and fitting resistors to give an extra-slow speed we've just about got it to the point where they can stay on and the place isn't too bad now. But it's still expensive to run (oil - no mains gas) and I'd hate to think how much it would cost to heat by electric.
UFH is definitely the way to go in terms of heating, but direct electric would probably be the last choice for running costs. Mains gas & condensing boiler would probably top the list, followed by a heat pump - both wet systems. Oil or tank gas probably still come higher on the list than direct lecky.
BTW - one advantage of wet system is that they are limited in temperature to the temperature of the water going round. If someone puts a rug or carpet down on part fo the floor then that bit of floor can't overheat. Electric is constant energy - if you insulate part of the floor with carpet or furniture, then that part will get hotter (potentially a lot hotter) unless you have self-regulating elements.
Wet system, pipework and rads sited correctly is the best thing for a church in my opinion.
Maybe a couple of Myson low line fan convectors on a separate zone (drop out prior to service).
Infrared wall heater in transepts or other small rooms/areas that might be used on occasion or for small gatherings etc.
I agree, that's probably about the best option for retrofit. If the opportunity arises, UFH (wet), possibly in combination with rads if needed for total heat output gives the advantage of not leaving the feet as cold.
But whatever goes in, churches are usually a p.i.t.a. (and expensive) to heat.
Thanks for all your comments on this, I'll pass on the info to the church representative.
This might be a better idea than UFH for a church: I recall seeing these at a Christmas market in Berlin years ago, you paid a euro and got 10 minutes or so in them to warm up. (not my photo, stolen from the web)
Reply to Electric underfloor heating for a church? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
Conversation developed with a middle aged lady who has recently lost her husband. Note to self, stop walking dog around the graveyard Anyway...
My mother moved into her three bed home in 1960 and it had underfloor heating in the living room. I remember we used it when I was growing up in...
